![]() | Home > General > Front Whirring Noise |
Road speed dependent would suggest it wheel related - Does it vary on cornering - possible wheel bearing.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
It seems to be always there but most noticeable (road speed noise vs noise) around 50mph. Doesn't seem to vary with direction of wheels but then only minor change in direction at speed. Can't hear it at very low speed. |
+1 for bearings?
PHinett Member Since: 21 May 2014 Location: Birmingham Posts: 63 ![]() ![]() ![]() |
Think I have the same issue...more like a squeel though rather than a whirring noise. It's not the breaks because they have a different pitched squeel when breaking at slow speeds.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9136 ![]() ![]() ![]() |
You say you have Grabbers fitted - are they the Grabber AT? If so, I've found that they are quite noisy at some speeds particularly around 30mph and 55-70mph. It's a droning noise that doesn't change much over the speed range and is the same whether on throttle or the overrun. 2012 SDV6 - it's missing a couple of cylinders
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
i would say the grabbers are causing it ,i had a sport with them on once and i thought the diff was |
