![]() | Home > Faults & Fixes > Suspension fault maximum speed 30 mph |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Sounds like the compressor is tired. Could indicate a leak somewhere or could just be the compressor on its way out. 2012 SDV6 - it's missing a couple of cylinders
might want to see if its one corner or all.
AlanEricThompson Member Since: 14 Oct 2013 Location: Nuneaton Posts: 96 ![]() ![]() ![]() |
Rang my dealer today they said ring LR assist, I did this and two guys came, plugged in a PC and suggested
When the car went "bouncy" did it drop down on to its bump stops? If so, that might indicate a cross axle error which might indicate a faulty sensor or a corrupted calibration (so called plausibility error I believe). 2012 SDV6 - it's missing a couple of cylinders
Yes I think it did go to bumps stops.
Oh well, collected my RRS from sytners today, no fault found.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4505 ![]() ![]() ![]() |
I had a cross articulation error on my D3. Caused by a soft tyre... |
Hi Disco
Mine looked a little soft. When checked, it was down to 16psi, when they are normally up around 40psi (little higher than normal, as the Disco is usually fully loaded) |
Tyres all checked out ok. 3.0 HSE RRS Stornaway (current)
It's back in the workshop!
Collected my RRS today from the dealer, they have fitted a rear height sensor.
Did they carry out a calibration after fitting the new sensor? If it's throwing up an error because of cross articulation that's a likely cause - calibration corruption. 2012 SDV6 - it's missing a couple of cylinders
Not sure.
