Home > Faults & Fixes > EPB issue
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
EPB issue
I've had this happen twice in 3 years. Parking brake activated while driving. Spooky enough on the same road.Anyone else had the same? So my question is do I buy a new module? Thanks.
Post #429600 Mon Jul 07 2014 6:54pm
Mister B
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Don't know but what happens Shocked
Post #429631 Mon Jul 07 2014 8:40pm
SCdavies
The car vibrates and the rear brakes get very hot. The rear parking shoes are designed or so i've been told to just break up under these conditions and so dont cause a lock up.
Post #429699 Tue Jul 08 2014 6:09am
Disco_Mikey
Does it actually activate, or are the shoes seized, causing it to bind? Do you use the handbrake often, or does it not get used?
I would imagine if the EPB is coming on, the car would beep at you to tell you so.
Post #429701 Tue Jul 08 2014 7:25am
Alex C
2008 Range Rover Sport TDV8 HSE Java Black
Had exactly the same, it is not activating as you are going along, just not releasing properly. Or has been over tightened when new brakes put on - mine ate a set of shoes for no apparent reason after I bought it. The previous owner didn't use the EPB and I did, that exercised it then it got stuck and did exactly what you describe. If you get the vibrating you know there is an emergency release under the cup holders in the centre console which you pull to disconnect it?? Got me out of trouble when they bound up on a motorway. TDV8 Java Black, Overfinch 22s
Post #429702 Tue Jul 08 2014 7:38am
SCdavies
Yes it was the same. no dash lights etc they just started to enaged while driving. My shoes were new ish the second time it happened. i do use the brake and so lack of use it isn't. When it did happen i didnt have to use the pull cable method as the switch still worked. I can hear them coming on or off. So do i wait for it happen again? maybe it will maybe it won't happen Question or shall i replace the module to be sure? £350 ouch. Thanks for all your replies. Did you replace you module Alex?
Post #429714 Tue Jul 08 2014 10:43am
I wonder if the EPB system wasn't correctly bedded in / adjusted when it was last changed. Might be worth having that done first. 2012 SDV6 - it's missing a couple of cylinders
Post #429717 Tue Jul 08 2014 10:56am
Alex C
No I never changed the module. I agree with RRStdv8, get the adjustment checked first. I took mine into my local dealer and they sorted it, new shoes were about 170 quid so you don't want to destroy them by just leaving it alone and seeing if it happens again... TDV8 Java Black, Overfinch 22s
Post #429746 Tue Jul 08 2014 2:59pm
Disco_Mikey
There is an official method of adjustment in ToPIX, or in Bodsys brake bible Thumbs Up
Post #429747 Tue Jul 08 2014 3:03pm
SCdavies
Thank you all.
Post #429790 Tue Jul 08 2014 7:42pm
waylander
United Kingdom 2012 Range Rover Sport SDV6 HSE Baltic Blue
really dumb question - how do you not apply the PB, I thought it was automatic?
Post #429853 Wed Jul 09 2014 7:13am
SCdavies
depending on year of model. there is a pull switch on the center console. up for on down for off, foot needs to be on brake pedal when doing so.
Post #429906 Wed Jul 09 2014 1:34pm
