Home > Technical > ARC failure
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
ARC failure
The 'Vehicle lean when cornering' message came up a few months ago and boy, yes, whilst doing xxx mph the handling was certainly different. Anyway, stopped and restarted the car and all fine. Happened again this evening. The again on the way back.
Anyone else had this? It's a 2012 car.
Post #429233 Thu Jul 03 2014 6:57pm
adigorn
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
fluid level low due to leak from bar
or g-sensor (or wiring), or valve block pressure valve (or sensor)
if fluid level is correct - Fault read it
Post #429260 Thu Jul 03 2014 9:39pm
