Home > Technical > HDC Disabled, Transmission fault Special Programs disabled
tailormadefun
United Kingdom 2006 Range Rover Sport Supercharged Zermatt Silver
Hi all
went out shooting this morning, on the way way I got the dreaded HDC Disabled, Transmission fault suspension lowered Special programs disabled, however the suspension didn't lower and the car didn't go into limp mode.
So I checked the brake lights, neither were out, and then I had the battery checked at STS and it was absolutely fine.
So I decided to change the brake lamps anyway and found water in the connector, so I dried it out and spayed in some WD40, d dried again and then disconnected the battery and Voila, one working RRS again!
just thought I would share this in case any one was having similar issue
TMF
2006 RRS 4.2 SC
Post #425806 Sat May 31 2014 6:23pm
stevew
United Kingdom 2009 Range Rover Sport Supercharged Zermatt Silver
I had the same thing happen me to me, but it was found that my rear diff motor had packed up, luckily enough I had extended warranty and my local dealer replaced it. I was told that it would have cost me about £600 if I did not have the warranty
Post #425840 Sun Jun 01 2014 6:23am
Nickr6r
England 2005 Range Rover Sport TDV6 SE Rimini Red
Hdc fault
Hi guys I'm new on here and not to sure how to use the site so please let me no if I'm going wrong rite I have if problem with my 2005 rrs tdv6 I jump in and start it up and I get hdc fault system not available / suspension fault /transmission fault and the car is as low as it can go and will not raise also green lo mountain light flashes all the time with amber lights ether side can any one shed any light
Post #428796 Sat Jun 28 2014 11:22pm
Disco_Mikey
Nick, it could be anything. You will have to have the car plugged in, to diagnose any fault codes stored.
However, the brake pedal switch is a very common failure, as is issue with the brake light bulbs.
It would be well worthwhile spending the £25 to replace all of these, just incase this is where your issue lies. There have been an alarming amount of D3's/RRS's left stranded by a faulty brake light bulb/switch Thumbs Up
Post #428797 Sat Jun 28 2014 11:29pm
MartyRRS
Australia 2008 Range Rover Sport TDV8 SE Alaska White
If the problem is still there after replacing the bulb and/or brake switch you could try replacing the fuel filter, especially if it has not had a good or regular service history. On my TDV8 RRS it was the fuel filter that caused the cascade of warnings. Good luck, and as Mikey said, try and get your codes read too. Regards, Marty
Now: 2008 RRS TDV8; 1975 Rangie ute
Then: 2010 Defender Puma TdCi 110; 1996 Defender 300Tdi; 1997 Disco V8 on vsi gas; 1976 Rangie 4.4l; 20 yrs of back breaking Tojos
Post #428800 Sun Jun 29 2014 3:06am
Nickr6r
Thanks i will get it plugged in as iv change the battary for a new s5 bosch and replace the brake peddle switch .dont no if it makes a difference but my brake swich was blue and white but the one i got to replace it was blue and brown they assured me it was the right one but coule just have said that to make a sale .any way i will get it plugged in asap thanks
Post #428815 Sun Jun 29 2014 10:22am
Nickr6r
Also forgot to mention i blanked of the egr's but thats seemed to be fine when i did that
Post #428817 Sun Jun 29 2014 10:34am
Eballs28
United Kingdom 2006 Range Rover Sport TDV6 HSE Giverney Green
Just to add my input, I had the same problem, and new battery didn't help. Checked bulbs and all ok. So got a new brake light switch for £5 +VAT from Island 4x4 and it solved all my problems!
Post #428891 Mon Jun 30 2014 10:20am
Nickr6r
I replaced the brake light switch and still no different cost me £20 was blue and brown is there another brake light switch ?
Post #429102 Tue Jul 01 2014 10:24pm
adigorn
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
i would start from checking Transfer Case ecu for corded connectors
from your description most likely the cause
have you power washed engine bay lately? Whistle
Post #429115 Wed Jul 02 2014 6:58am
Nickr6r
Ye i did power wash under the bonnet when i got it as the whole car needed i good clean ill have a look and see what i can see thanks
Post #429137 Wed Jul 02 2014 12:48pm
adigorn
So at least no one else to blame Whistle
Post #429159 Wed Jul 02 2014 6:20pm
Disco_Mikey
Post #429168 Wed Jul 02 2014 8:54pm
Nickr6r
Well thanks very much disco_mikey you was spot on was the ecu plugs that were corroded took it out give it a good clean and the car runs spot on no faults at all thanks for everyones help
Post #429229 Thu Jul 03 2014 5:54pm
Nickr6r
My transfer case ecu and plugs cant belive it .this is a great site thanks again disco-mikey
Post #429289 Fri Jul 04 2014 7:37am
