![]() | Home > Maintenance & Modifications > anyone replaced rear anti roll bar ? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Have replaced a few of the rear ARC actuators. Same process. Needs the back of the body raised from the chassis to get the bar out and in.
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 ![]() ![]() ![]() |
Cheers Mikey
Not particularly difficult.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9132 ![]() ![]() ![]() |
If it's an active anti-roll bar then you're looking at over £1k to replace it - it's about £800 for the part alone IIRC! Rear bushes would be <£200 fitted. Even if they only lasted a year it would be cheaper to have them done as an annual service item than get the bar replaced.
Don't think it's an active bar as they also mentioned a wishbone and a ball joint i think and suggested it would be less than a grand |
I would still be doing the bushes. If needed, shim them too to tighten everything up that bit more |
Thanks for reply Mikey, what, just the bushes onto the existing roll bar ? do you reckon they might last a year or so then?
Update,
