![]() | Home > Faults & Fixes > Suspension Fault |
| SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324
Hi, it would be a good idea to get the car plugged in to read the fault codes. Indy or dealership. Sounds like the common problem of new compressor required. £500 fitted. Brakes sound like warpped discs. What's your mileage? |
| Becks Member Since: 28 Jun 2014 Location: Surrey Posts: 6
Mileage is 100,000.
| Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263
New discs and pads on the front sorted out my steering wheel vibration. |
if you have no records of a replacement compressor or brake discs then I think these items have done well considering your mileage. Time to replace. Met tec brakes are super value. And if your buying a front set remember to replace pads too. Also I have a new pair of rear disc for sale from met tec if you wanted match the front. Slotted and grooved.£50 for the pair plus £12.50 for posting. Fronts are cheaper due to the rears having the brake linings. Fronts should cost you £75 for the pair. |
Thank you, had the discs checked and they look like they have been replaced so not that (unfortunately) as that sounded an easy fix. Unless they have warped as not sure when they were replaced I am just told they don't look like they are warn! Very odd as it drives really well! |
Will definitely book in to have compressor done... once found local expert!
| simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114
try changing the brake peddle switch £15 common fault, |
