![]() | Home > General > Warranty issues |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
That's just poor service. Not all dealers are the same. I had a similar problem on a full fat with flickering headlamps. Guy salmon said "supposed to do that sir, it's characteristic" where as stratstone correctly diagnosed a fault and replaced both headlamps.
Chin Member Since: 02 Sep 2013 Location: London, UK Posts: 66 ![]() ![]() ![]() |
does anyone know if the approved used warranty is provided by land rover, or by a third party?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155 ![]() ![]() ![]() |
Car Care Plan 2012 SDV6 - it's missing a couple of cylinders
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
Just add it to the list of bad customer service from land rover.
They will certainly feel the wrath of social media /letters of complaint soon enough.
Get in touch with Customer Relations, throw a polite tantrum and then ask to escalate to executive office as this all sounds like BS. If they feel you have been wrongly refused, they will put pressure on Carcare Plan to get work done. Software updates are not usually covered as dealership should provide this gratis if there has been an update 2x TDV6. SE and HSE. Both returned to sender with issues👀
If you read the handbook that comes with the warranty, you'll see what they state is not covered. Software upgrades aren't covered unless part of a repair to something else.
Yes seen in the hand book about software update.
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 ![]() ![]() ![]() |
I read all these issues and I am seriously considering selling my2011 RRS and going to something from Merc great service, warranty and support or Hyundai Santa Fe. Don't all be shocked but what does LR expect. Eventually it will come home to roost. |
A2LUA Member Since: 02 Jul 2011 Location: Cumbria Posts: 16 ![]() ![]() ![]() |
Hi I had the same problem with the fuel sender they tried the software update but this didn't work so the fuel sender in the tank had to be changed apparently theres a modded part and a fairly common fault all under the approved used warranty. |
Great thanks all.
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 502 ![]() ![]() ![]() |
Yep. Had my fuel tank sensors changed recently under extended warranty (2011) no quibbles ![]() |
Thanks - can someone help explain why they pay out for some customers but not others?
I guess there is a difference between the way different dealers approach the warranty company. The warranty company only want to pay for stuff that's failed, generally, so if a dealer says "the part is worn" they probably say "no". If the dealer says "the part has failed" then they pay out. I think they also send out assessors to check that stuff does need doing. Maybe it depends on a combination of things.
