| RRSPORT.CO.UK | ||
|  | Home > Off Topic > Do you switch your air con off to save Fuel? |
| JPR 1 Member Since: 29 Jan 2013 Location: Cheshire Posts: 435      |
|  Mon Jun 09 2014 10:42am |
| jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1924    | +1
|  Mon Jun 09 2014 10:45am |
| JimR Member Since: 20 Dec 2013 Location: Lichfield Posts: 66      | Mine is on Auto all the time. It also de-humidifies the air and helps stop misty windows in the winter.
|  Mon Jun 09 2014 10:51am |
| SPX Member Since: 26 Dec 2012 Location: South Yorkshire Posts: 587      | I always have the air-con on through summer AND winter because of instances like that in the OP.
|  Mon Jun 09 2014 11:17am |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | I seem to remember that on a 38A the default setting was ON. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
|  Mon Jun 09 2014 12:05pm |
| BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942      | I run mine constantly, just adjust the temperature. If you don't run it, it will get smelly when you do, like a stale urine smell. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
|  Mon Jun 09 2014 3:02pm |
| Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278    | I leave mine off, but turn it on regularly to lubricate the seals. If left on for long periods I find it dries my mouth & nose up a bit as it removes moisture from your body too.
|  Mon Jun 09 2014 3:07pm |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716    | on all the time .....
|  Mon Jun 09 2014 3:34pm |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644    |
|  Mon Jun 09 2014 3:44pm |
| RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797  | So you just leave the econ light off then it kicks in the AC as and when required? | ||
|  Mon Jun 09 2014 4:37pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | I've always had my air con / climate control running all the time in all of the cars that have had it fitted. I heard long ago about the issue with seals etc. drying out. But more importantly is that I want the air inside the vehicle to be at the correct temperature and humidity - that's what the system does after all!
|  Mon Jun 09 2014 4:56pm |
  just a average day in the life of dropping kids off   | ||
|  Mon Jun 09 2014 6:21pm |
 Half a mile? Make the little darlings walk!  2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed | ||
|  Mon Jun 09 2014 9:26pm |
| Posting Rules
 I guess you can only warn people!!
