![]() | Home > In Car Electronics > Head Light Bulbs |
Ade99 Member Since: 28 May 2014 Location: wombourne Posts: 23 ![]() ![]() ![]() |
Hi have just bought an 08 plate 3.6 TDV8 sport. Reading the handbook It says you can change the xenon bulbs yourself
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
Should be 55W D2S at 4300K, I think.
OK thanks will have a look and see what I can find. It was the numbers after the bulbs that I couldn't under stand as some were listing 6000k, 8000k and 10000k.
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
I suggest you do not trust the manual.
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 ![]() ![]() |
But incorrect bulbs may have been installed before. |
Well, my bulbs were never replaced, still the original as fitted by the factory.(They are bixenon, adaptive)
I'm not saying don't look, checking will at least re-inforce what you have just stated for the correct bulb fitment, but it might not highlight which is the correct temperature. Sorry for causing any confusion there. |
japaaa Member Since: 04 Oct 2013 Location: Sao Paulo Posts: 4 ![]() ![]() ![]() |
I checked my handbook and it also says: Xenon Bulbs D2S 55W
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 ![]() ![]() ![]() |
FYI the higher the colour temperature the more blue the appearance of the light.
