Home > Maintenance & Modifications > heater/blower not working
bubba
Hi, apologies in advance if this doesn't make sense but i'm trying to get some info on how to fix a problem so I can order any bits I might need in advance of my husband coming home from work in 2 weeks so he can fix it!
basically the blowers have stopped working. No funny noises or warnings at all so no clues there. I have done a bit of research suggesting it could be the heater blower resistor? Is it worth ordering one, or are there any other things I could try?
Thanks is advance.
Post #425476 Wed May 28 2014 12:15pm
Michael calvert
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Nara Bronze
fuse? 2010 RRS HSE 3.0 tdv6 2010MY
2012 Audi a5 2.0 tdi s-line
2005 Discovery 3 tdv6
2009 audi a4 2.0tdi saloon
2007 Audi a3 1.9tdi sportback
2004 Navara Double Cab
1996 Shogun 3.0 v6
1984 Landrover 90 2.5d
Post #425484 Wed May 28 2014 2:47pm
Texstar
Fan relay in engine bay fuse box ? You can try swapping with another of same type to check this. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #425643 Fri May 30 2014 1:27am
Disco_Mikey
Generally, it is the relay under the bonnet that causes the issues. Easy enough to swap with another one, and it wont cost you anything to try Thumbs Up
Post #425645 Fri May 30 2014 6:57am
samson
Poland 2005 Range Rover Sport TDV6 HSE Siberian Silver
Just want to say thanks! You saved my life. It's winter now in Poland and by blower stopped. Swapped relays and its working perfectly.
Post #444749 Tue Dec 09 2014 9:57am
