Home > Technical > Some Electrical Gremlins
tokerev1
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
hello.does anyone know anything about the receiver for the remote control fob.? my RR key fob worked when it felt like it,so i did what the book says and put the key in to recharge,it still only works sometimes.so i have to get in the car by key entry which means its not alarmed.so took it to the RR dealer they said its a common problem and the key needs replacing,£260 quid later I've got the new key and it worked for a few days and now its not,took it back and they want it for a few hours to take the carpets and seats out because they say its the receiver and its under the back seats that means another big bill,goddammit,.so,I've come on here first to see if anyone knows anything about this problem,they said the wiring might be worn or somehow got wet,???.im not so sure,idont want to get ripped off do would be grateful is anyone could help me . Shocked thanks its a 2007 sport HSE .
Post #425012 Thu May 22 2014 4:06pm
Disco_Mikey
Green/White wire splice joint, in the N/S sill Thumbs Up
Post #425021 Thu May 22 2014 4:29pm
tokerev1
cheers pal,your a star,. Thumbs Up do you know how i get to it,is it an easy job.?
Post #425038 Thu May 22 2014 7:03pm
Stuart
Stuart wrote:
"Suspension fault - normal mode only" lights.
They plugged it in. Seems this is the compressor. Big Cry
Post #425412 Tue May 27 2014 6:04pm
Disco_Mikey
Needs the trims pulled up, and the splice joint cut out, and re-made. Easy enough to do Thumbs Up
Post #425511 Wed May 28 2014 9:12pm
tokerev1
nice one mikey,thanks again Razz Thumbs Up
Post #425556 Thu May 29 2014 10:42am
