![]() | Home > General > First two months of ownership |
| Andy1234 Member Since: 18 Mar 2013 Location: Salisbury Posts: 17
Sorry I also forgot to say that the dealer did a end of warranty check. They said that the passenger side front wheel is not running quite true. Added to that they say that non standard brake pads have been fitted & the discs have high & low spots on them. They say to replace the pads & discs would cost over £900. Again regarding the discs is this normal for a car with only 30,000 miles on it ? 2011 HSE Luxury, Stornaway Grey, Lux Pack, Privacy glass.
| fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216
When you say "non standard" brake pads does that mean somehow the wrong type or just non OEM? Just wondering if those pads could have caused uneven wear on the discs.
I think they were the right pads, just not OEM. The dealership seem very fair with the way they have diagnosed the existing faults & rectified them under warranty, however I wondered if they were being slightly too cautious regarding the discs. I am due to pick it up at the start of next week so I will take your advice & get a second opinion. Thanks
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Interesting to know how they diagnosed high and low spots, I have never seen a dti in a modern workshop and due to the nature of the disc fitting, impossible to test on the car as needs wheels on to run true and I'm sure they didn't strip the discs and put them on a lathe. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 256
I have a similar car to you, albeit in Bali Blue and it needs new discs and pads all around! I'm getting a quote from a local independent in Salisbury on Monday, I suspect it'll be less expensive than a dealer but I don't know whether there'll be warranty issues with the dealer; however, you would need to check if brakes are covered with the Land Rover one. |
Not sure what your cars are, mine needed pads @ 15000 miles and discs once in 50k miles. Having said that, I used the car mainly for towing and got lazy in the end and just used the pedal instead of using gearbox to assist. Went with genuine front discs and pads £350 and copy rear discs and pads at £95. Factor in pair of pad sensors as usually brake or won't refit at £30.
Hi SalisburyLander, thanks for that. Westover Salisbury are quoting as I said in an earlier post over £900. I am also going to renew the genuine Land Rover warranty because after the start I have had to RR Sport ownership I can see eye watering bills possibly just around the corner !!!
I agree with you Simple1, the cost of changing discs and pads should be a lot less than the £900 quoted by the local dealer!
There is an MoT test insurance upto £750 included in Land Rover warranty IIRC. That might be the only time the warranty could pay for discs if the discs are one of the reasons for test failure. Check the warranty policy document (online if you don't have the printed one) to be 100% sure though. |
| SingeRRS Member Since: 22 Sep 2009 Location: Garage Posts: 127
My MY10 RRS has now covered 36k miles - I was told from the second service (2 years old and c. 18k miles) it needed new discs and pads by a franchised dealer. I ignored them because they couldn't tell me convincingly how worn the pads were when I questioned them ("oh about 60% sir" - "so how much pad is left in mm" - "errr -what?")
Rules around brake discs for mot are fairly easy and unless they are cracked, and the pads have a micron of lining, you will get an advisory which doesn't count as failed item under LR t&c's. It will cover suspension arms, bushes, ball joints etc even brake pipes. I wouldn't be too concerned that your car needs discs at 30k, about the point I replaced mine, you are trying to stop in excess of 2.5 tonnes so things are going to wear...... TDV8 Sport HSE...... Gone. Loved it but it didn't love me!! Now rolling in MY10 Fullfat TDV8 Vogue. Slammed it to go round corners🙈 Cruising daily #56 mph in a Volvo V8. 😱 Lots of other toys in the cupboard...😜 |
Good to know |
| All times are GMT |
