![]() | Home > General > Front Suspension Slow to Raise? |
| daveyc Member Since: 09 May 2014 Location: Liverpool / Spain Posts: 56
Sounds like the compressor if you can get a code reader possible with isolate your fault , very common to have faults on, got a problem with mine at the moment but code showing control unit fault , I can inbox you the workshop manual if u want .. 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9154
Could be the front valve block. Could be the reservoir valve block (splits air to the front and rear and the reservoir). Both parts are less than £100 and possible to do DIY apparently. 2012 SDV6 - it's missing a couple of cylinders
