![]() | Home > In Car Electronics > Phone dialling using voice recognition |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
yes i believe you do ... if my memory serves me right. I remember when i set mine up i had to sit and manually interact with the system to input peoples names, which is the option i took, it basically records your voice when you input a name. i know there is a section in the manual that explains how to do this. i think there is an option to input numbers as well... first step is to make sure your phonebook has downloaded to the system. 2010 RRS, TDV8
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 ![]() ![]() |
Think it will depend on the cars bluetooth module. My 2013 Black Edn downloads the contacts ok from my iphone 4 |
Jens0n Member Since: 03 Dec 2013 Location: Mos Eisley Posts: 76 ![]() ![]() ![]() |
On your phone:
sundeepbakshi Member Since: 17 Apr 2014 Location: berkshire Posts: 13 ![]() ![]() ![]() |
Cheers. So the Bluetooth settings are correct.
I had to add voicetags vs using the phones speech recognition.
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
My contacts are there but I don't seem to be able to use voice recognition to call people. |
I'll give the handbook a last shot but I think I'll take it to landrover. See what they say. I will post when I know. |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1903 ![]() ![]() |
I think Jens0n has given you the answer. 2023 P440e SE Dynamic on order -cancelled
as i said.... you will have to add contacts manually if you want to call someone by name, how else would the system recognise who you wanted to call. When you download your phonebook it only transfers numbers, when you set up voice recognition you speak the persons name you want to store, it records the name then associates a number with it. when you activate the voice command it asks for a name, it will play back the name you ask for then dial the number it is associated with. its sounds long winded but it only takes a minute to enter a stored name... or number, whichever option you use to dial out. 2010 RRS, TDV8
JimR Member Since: 20 Dec 2013 Location: Lichfield Posts: 66 ![]() ![]() ![]() |
I went through the process of adding voice tags to some of my contacts. It still rarely works. Even though it accepted the tags, "phone Rita" becomes "phone redial", "phone grandma" becomes "phone cancel". I gave up in the end.
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
My son has a 58 plate grande punto worth about £4k and I can voice dial any of my contacts by saying "call ****" |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 ![]() ![]() ![]() |
I sat the very night I got it and added all the names, it works flawlessly! It must be my Liam Neilson Northern Ireland Accent makes it afraid to not get it right. |
