![]() | Home > Technical > Faulty brakes..... I think... dealer canīt figure |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
Altitude and temperature could impact the system if there was a chance there is moisture/air in the brake fluid /servo/pump / system which is confusing the pressure sensors/anti-lock system ? |
| andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155
Thank you Dr... that goes on the list of suggestions to the dealer..... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
| B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450
have you had new brake pads fitted recently ? |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003
Since it releases the brakes when you pump the pedal it might be a fault in the servo.. 2008 G4 RRSport TDV8 current
Dealer changed the pads and discs recently....to try and resolve the fault , whilst it improved slightly it was still happening after they had been fitted....
| JOHNNY FEW Member Since: 30 Jul 2011 Location: herts Posts: 11
Hi I had a similar fault like this one a few years ago on different make of car,after changing master cylinder,servo unit and pads discs etc we finally found the culprit a over adjusted brake light switch fitted to the foot brake pedal worth a look |
| All times are GMT |
