Home > Technical > Front brakes please help
dab130283
United Kingdom 2005 Range Rover Sport TDV6 HSE Adriatic Blue
Hi has anyone had problems with front brakes I fitted new britpart discs and EBC pads all was fine for a little while then they started squeaking. I took them out re checked all was fine put them back and they still squeak so now I have fitted brembo pads and guess what they still squeak it's driving me mad someone please help
Post #422883 Wed Apr 30 2014 6:54pm
C11RRJ
England 2007 Range Rover Sport TDV6 HSE Java Black
Apply some copper slip to the rear of the pads and on the ends that go in to the spring clips 👍
Post #422888 Wed Apr 30 2014 7:20pm
dab130283
Hi I have tried copper slip on both sets of pads. I have changed loads of pads in the past and never had this problem.
Post #422892 Wed Apr 30 2014 7:40pm
Disco_Mikey
Britpart discs Whistle
Made in China, for, quite literally, a few pounds each...
You don't say which EBC pads you have, but the ceramic pads to tend to squeak, until they have bedded in fully. A couple of high speed stops should sort that out Whistle
Post #422903 Wed Apr 30 2014 8:09pm
dab130283
Hi mikey
They wasn't ceramic pads but I have now replaced them with brembo pads. I have got a feeling it's wheels off and discs off and replaced again as it can only be the disc now you wouldn't think the disc would cause the squeaking.
Post #422908 Wed Apr 30 2014 8:29pm
Disco_Mikey
When it comes to Britpart (affectionately known as Sh*tpart) anything is possible Rolling Eyes
Post #422912 Wed Apr 30 2014 8:45pm
dab130283
Just found a new set of brembo discs for £90.00 the pair so think that will be the best option what do you think
Post #422917 Wed Apr 30 2014 9:20pm
Disco_Mikey
As long as you can be sure they are genuine Brembo discs
Post #422930 Wed Apr 30 2014 10:41pm
dab130283
Well this is the problem they are from a motor factors on line
Post #422934 Wed Apr 30 2014 11:32pm
Disco_Mikey
£90 sounds a little on the cheap side.
If in doubt, buy from a trusted source: http://www.advancedfactors.co.uk/bd-098877...2533-p.asp
Post #422943 Thu May 01 2014 5:42am
dab130283
Thanks for the link.
The discs I'm looking at are in a sale the was ment to be £135.00 the pair.
Post #422945 Thu May 01 2014 5:56am
