![]() | Home > General > Stablity Problem |
speedy2009 Member Since: 04 Apr 2014 Location: driffield Posts: 35 ![]() ![]() ![]() |
Is it like it's tram lining ? |
tailormadefun Member Since: 06 Apr 2014 Location: Kent Posts: 51 ![]() ![]() ![]() |
My 2006 is the same, I've had it checked and it's all good so I guess it is one of those RRS peculiarities
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4528 ![]() ![]() ![]() |
22" wheels tend to be wider, and will be a lower profile than standard sizes, and as such, will pull, and tramline more than those on 19"-20" wheels Any play in suspension bushes will also affect it. That, and some of the roads up in Scotland can be pretty shocking... If you have access to another set of wheels, I would try them first ![]() |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
19"wheels would make a massive difference,but wouldnt look half as good |
Saeedasghar Member Since: 11 Dec 2012 Location: Worcester Posts: 104 ![]() ![]() |
I had a similar problem the back would step out slightly at 30mph on local roads whilst going over a small bump or little ditch in the road. Had the alignment done all sorted now. Maybe worth while getting that checked first maybe. |
futureian Member Since: 29 Dec 2013 Location: Scotland Posts: 22 ![]() ![]() |
Yes, on occasions that is what it can do. |
Tram lining – Yes, that is what it can do.
