![]() | Home > Technical > Wet Passenger floor |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Air conditioner drain blocked perhaps?
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
Yes check the a.c drains but I recently had this issue and I found that in heavy rain or when parked down hill the water come in the bottom hole on the A pillar. The outer trim finisher has the clips that hold it on - they go in small round holes but at the bottom the hole is elongated where a positioning moulding goes in and this lets water in.
ICMarshall Member Since: 06 Feb 2013 Location: Oxfordshire Posts: 3 ![]() ![]() ![]() |
It was the hole at the bottom of the A-Pillar that was letting the water in. Now fixed and dry, details on Technical Bulletin LS501-006.
Hi Guys,
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Aargh.
Pakolainen, if you haven't already done so, please check your sunroof and drainage channels and tubes, as this is the most common fault for getting the wet floor-wells. This may not be the cause but it is the first check to do IMO. Once ruled out, then check the window seal and co ear as mentioned above.
Cheers Johnski,
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, it was the slot in the a pillar on mine that was the problem, not the sunroof. I followed the instructions on here and now it is bone dry, when i opened the door it poured out and it took 4-6 weeks to dry out. I put some clear sealant around the replacement clips, plugs when i done the job, don't just fitt them dry or it will not work, just covered the slot with duct tape. Hope this helps, it done mine |
Hi, forgot to say that the foam block becomes full of dust and dirt preventing the water to run out, it then back fills up to the slot and in. Don't forget to remove the foam block when you do this |
Have opened the sun roof and the spacing around that was all dry, inserted a straw in the drainage holes and blew - no resistance. and the internal roof shutter for the sunroof is dry.
Hi, i'm sure you will find it s the slot problem, it is an easy fix |
Graz Member Since: 22 Apr 2013 Location: Essex Posts: 104 ![]() ![]() |
Apologies for my ignorance but given this was a service bulletin, are LR providing this A pillar fix for water ingress free of charge? |
Hi, unsure my friend but no doubt someone on here will know and inform you |
Evening.
