Home > General > Pants, lost my lock nut! Only a week into owning the thing!
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Any ideas how I go about getting the OEM lock nut?
Post #422416 Sat Apr 26 2014 9:30pm
designboy
I just ran a search here. Turns out I'm not the first. Good advice here too to get it sorted for under a tenner ; )
Post #422419 Sat Apr 26 2014 9:44pm
You could go to your local LR dealer and ask them to remove the old locking nuts and then put a fresh set in. LR dealers have a full set of locking nut keys. 2012 SDV6 - it's missing a couple of cylinders
Post #422457 Sun Apr 27 2014 8:30am
Disco_Mikey
Even better advice is to have lockers removed, and replaced with normal wheel nuts Thumbs Up
Post #422459 Sun Apr 27 2014 8:44am
Andi
Why do you say that Mikey?
Post #422482 Sun Apr 27 2014 12:07pm
BKHK
Where was it, in the pocket of your pants? I don't understand the connection between your pants and your lost nut? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #422508 Sun Apr 27 2014 4:25pm
He was using the word "pants" as an alternative to one of the usual expletives...but I reckon you knew that Wink 2012 SDV6 - it's missing a couple of cylinders
Post #422522 Sun Apr 27 2014 6:58pm
Disco_Mikey
Because they have a nasty habit of splitting, and falling apart. All of the strength is in the outer part of the nut, which splits and falls apart.
When that happens, the softer steel is not strong enough to undo the wheel nut, and so, leaves you stranded at the side of the road...
Post #422536 Sun Apr 27 2014 8:12pm
Andi
Very interesting, thanks for the reply Mike. Thumbs Up
Post #422538 Sun Apr 27 2014 8:19pm
BKHK
Thanks much RRS Tdv8, I didn't because it's not an expression we use here. Pants or Strides or occasionally trousers are what you call trousers. We would just say F . Thanks, it's a new one I will use like minger (a short version of that means something else too) Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #422555 Sun Apr 27 2014 10:32pm
tanloverluke
my local garage tells me that every time i go there to change tyres/wheels/fix puncture.
there must surely be a locking nut stronger than the lr oem ones, anyone ? pulling up an image search gives me this:
https://www.google.co.uk/search?q=locking+...p;tbm=isch Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #422556 Sun Apr 27 2014 10:42pm
DrLex
Iceland
Having read plenty of threads where locking nuts have caused problems, and only one report of wheels stolen from the hubs (that had locking nuts), I can't really see the value in such, especially given the easy availability of tools to defeat them. Rather than buy a replacement key, I'd suggest doubling the budget and buy four regular nuts.
Post #422578 Mon Apr 28 2014 10:52am
Alloy wheels used to be relatively rare things and so were prone to being stolen. Now that almost every car produced has alloys they are probably not worth the time and effort to steal them. Especially when one considers how easy it appears to be to steal the vehicle itself with the wheels attached!
I can see how someone with pristine diamond turned 22s might be worried about theft - these are still quite popular items it seems (along with facelift lights of course). I doubt scratched 19s are much of a target (I hope, as that's what is on my RRS). 2012 SDV6 - it's missing a couple of cylinders
Post #422584 Mon Apr 28 2014 12:25pm
Disco_Mikey
As above Thumbs Up
Post #422601 Mon Apr 28 2014 3:16pm
simple1
Agree 100% with DM. Having suffered the split locker and the local tyre monkeys not putting it on and twisting the groves, and the cost of getting it sorted as PROTYRE refused to accept responsibility, I had locks removed and standard nuts fitted as didn't want to be stuck on side of motorway at night with same problem 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #422784 Tue Apr 29 2014 9:38pm
