Home > Technical > Strange limited gears fault
Flatteraxe
United Kingdom 2007 Range Rover Sport TDV8 HST Java Black
Helo all,
Yesterday I was driving my TDV8 when I noticed that it had a little less poke than usual. Suddenly it was as if the engine braking came on and I pulled over, these faults appeared:
HDC fault
Limited gears available
the car also lowered to its lowest suspension settings
I turned the ignition off and restarted the car and all seemed fine, just not sure what could cause all 3 of these issues at the same time?
Post #422054 Wed Apr 23 2014 3:44pm
You need to get the fault codes read I'm afraid.
It's likely to be a brake system issue but could be anything from a brake pedal switch to a brake bulb. Could also be the alternator getting ready to die. Complex beasties these RRS. 2012 SDV6 - it's missing a couple of cylinders
Post #422058 Wed Apr 23 2014 4:21pm
Disco_Mikey
Brake bulb, or switch, or a blocked fuel filter
Need your codes read first Thumbs Up
Post #422091 Wed Apr 23 2014 9:05pm
