![]() | Home > Technical > Black smoke |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9148 ![]() ![]() ![]() |
It's a diesel, they all do that to a lesser or greater degree. Has it had a remap done? Excessive fuelling will cause black smoke. 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4529 ![]() ![]() ![]() |
Probably a split turbo hose. Very common on TDV6 |
chi Member Since: 15 May 2010 Location: hampshire Posts: 49 ![]() ![]() |
Had this very recently on my 55 plate tdv6. Black smoke on acceleration.
SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 541 ![]() ![]() ![]() |
Had the same AFTER the both EGR valves were replaced.
rich_z3 Member Since: 16 Feb 2014 Location: Runwell, essex Posts: 68 ![]() ![]() ![]() |
I had this it was a turbo hose |
Sag Member Since: 08 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
I had this - Tried blanking EGR valves & replacing Turbo hoses. Neither worked.
Split hoses / damaged intercoolers all lead to the same thing - over fuelling because the system expects a certain amount of air to arrive at the engine and some of it disappears through the hole before it gets there |
Chin Member Since: 02 Sep 2013 Location: London, UK Posts: 66 ![]() ![]() ![]() |
Could someone help me locate the turbo house to check this out please? |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
lift up your bonnet and look down at the engine, there will be two rubber pies/hoses, both identical, both running from the intercooler, one to each turbo 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
would you hear it Mike if the hose was split and would it put engine system failure light on as im having a similar problem with the sport i put an engine in silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !! Gone rr sport supercharged. Loved but 11mpg !!! current,triumph stag mk2...current bmw 325 sport convertible |
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 ![]() ![]() |
Mmmmm! Rubber pies. Would be the food that keeps you chewing forever. ![]() |
