Home > For Sale & Wanted > [For Sale] Decat Pipe for RRS
AdeParko
Scotland
For sale is a decat pipe to suit a RRS
Brand new, never got around to fitting it
Made from 409 grade stainless steel this down pipe for the TDV6 removes the restriction of the original CAT.
The catalytic converters fitted to most modern vehicles are a known cause of restriction to the flow of exhaust gasses known to cause turbo lag. Removing the CAT can increase power and reduce lag from the turbo by allowing the engine to breathe more efficiently. In some cases removing the catalytic converters can improve fuel economy. Bolts directly in to the existing system.
£90 collected or +£15 for courier p&p (or if can be arranged by D3 network?)
Thanks
Ade
Post #421284 Mon Apr 14 2014 3:05pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
what is it like to fit mate
Post #421325 Mon Apr 14 2014 9:20pm
AdeParko
Scotland
Not fitted it myself obviously, but would of fitted it DIY after looking at the guide below
Hope that helps
Thanks
Ade
Quote:
okay guys, this is quite a simple fitting
first you have 3 15mm nuts which you pre apply copious amounts of free off spray to allow safe removal with no nasty broken studs!!
[URL=]
[/URL]
you can see this is tight on room, but 1/2" drive with universial and fixed HEX sockets and a speed bar to loosen and then out the inboards come.
the outboard one, you can loosen and then from the wheel arch you can with a 15mm ring spanner remove it with no real problem.
this then moves on to the rear box joint which is imperial in socket size on the clamp.
this is undone fully to allow a figure of 8 wiggle to be setup between the pipes across the joint to ease off the joint and allow the pipe to slide out. as shown
[URL=]
[/URL]
this then allows us to now move on to the hanger that is all that is left keeping the front cat pipework attached to the car.
[URL=]
[/URL]
NOW!!!! you have 2 options
you can remove the main rear gearbox chassis member to release the old front CAT pipe from the car,
OR
you can cut the pipe behind the CAT to drop out the 2 parts!!
[URL=]
[/URL]
the new one fits into the car with the chassis member in place so depends if you want to keep the old CAT pipe for nostalga!! Thumbs Up
refitting is a case of copperslip the studs on the turbo, fit new gasket, and mount the new front pipe flange and fit the 3 15mm nuts and tighten.
then wiggle it into the rear system pipework and tighten the clamp, refit the front hanger,
slide from under the car and breath a sigh of relief!!!!
Tidy up, and wash up, go for a non restricted drive and even more power released
Thumbs Up Thumbs Up
Post #421331 Mon Apr 14 2014 9:43pm
Disco_Mikey
They are an Censored to fit Evil or Very Mad
Post #421334 Mon Apr 14 2014 9:51pm
Michael calvert
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Nara Bronze
2.7 or 3.0 tdv6? ? 2010 RRS HSE 3.0 tdv6 2010MY
2012 Audi a5 2.0 tdi s-line
2005 Discovery 3 tdv6
2009 audi a4 2.0tdi saloon
2007 Audi a3 1.9tdi sportback
2004 Navara Double Cab
1996 Shogun 3.0 v6
1984 Landrover 90 2.5d
Post #421337 Mon Apr 14 2014 10:17pm
AdeParko
Scotland
Sorry, forgot to mention its for the 2.7
Thanks
Ade
Post #421341 Mon Apr 14 2014 10:22pm
cossiedave
hows about 90 quid delivered mate
Post #421342 Mon Apr 14 2014 10:25pm
AdeParko
Scotland
Sorry. I may be able to trim a bit off by finding a cheaper courier, but not that cheap I'm afraid Sad
£100 delivered
Thanks
Ade
Post #421343 Mon Apr 14 2014 10:41pm
cossiedave
no worries mate just thought i would ask, martin at bellautos said its a garage job to fit it so need to allow for that mate
Post #421344 Mon Apr 14 2014 10:43pm
aljo
Will it pass the mot with this fitted Rolling Eyes
Post #421356 Tue Apr 15 2014 7:55am
tailormadefun
United Kingdom 2006 Range Rover Sport Supercharged Zermatt Silver
As long as the emissions are ok it will, but cut the old cat housing off your old one and weld it into place as the cat is now a visible check item on the mot
Les
Post #421362 Tue Apr 15 2014 9:56am
AdeParko
Scotland
My wifes Disco passed an MOT this month with one fitted, and there everyone over on the Disco3 forum who has one fitted have had MOT's within the past couple of moths with no problems Thumbs Up
Post #421366 Tue Apr 15 2014 10:22am
