![]() | Home > Maintenance & Modifications > Drivers inner door seal |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
It clips out - you may get a few inner clips move slightly - you will see what i mean after youve pulled up the trim - ( it will make more sense ). You may have to loosen the B Pillar upper trim ( again just pull slightly from the bottom up ) if you need to remove it completely.
