Home > Technical > Dipped beam too low.
Leasky
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Hello folks.
Got the vehicle a couple of weeks ago (2011 RRS 3.0) and love the thing. However, when driving back up from St.Andrews last night, it became very apparent that the dipped beam was not sufficiently high to allow me to see the road ahead as I should.
I cannot find anyway of altering the lights from within the cabin and I can't find anything within the users guide.
Pardon the pun but can anybody cast some light on this for me as how to raise the level of the lights?
Thank you,
Colin.
Post #420970 Fri Apr 11 2014 5:08pm
Camelrock
It will need to be checked / adjusted at a garage on a beam setter ( any MOT testing station has one) there are no height adjusters on the dash like on other cars because the car has air sus so will always ride at the same height .. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #421040 Sat Apr 12 2014 10:07am
Leasky
Thanks very much for that, can I ask if it's a big job ie is there simply a manual adjustment which can be performed on the lights or does it involve removing items and some proper tinkering?
Colin.
Post #421041 Sat Apr 12 2014 10:12am
Camelrock
No take about 5/10 minutes straight forward on RRS 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #421042 Sat Apr 12 2014 10:15am
SRE
Spain
Might be worth getting your ride height checked first. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #421044 Sat Apr 12 2014 10:19am
martyn05
I believe there are 2 adjusters on each headlight, one for up / down and the other for left / right.
Look behind the headlight and you will see the adjusters, they look like big grey screw heads.
IMO you are better off going to Kwikfit or similar and get then to set them properly Very Happy 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #421046 Sat Apr 12 2014 10:35am
As Martyn says, it's a simple job to do using the adjusters on the units. Of course, if you do it yourself it's best to go out to a quiet, flat, straight bit of road and adjust them. Otherwise a 5 minute job for any decent garage.
It's worth checking that the headlights go through their dance correctly - I've noticed that the driver's side unit on mine doesn't always dance back to the correct position resulting in a low beam on that side. 2012 SDV6 - it's missing a couple of cylinders
Post #421053 Sat Apr 12 2014 11:39am
dover
New Zealand 2012 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
My lights on low beam are I think too high because a number on coming vehicles flash their lights at me, what is headlight dance business and how do you test it ? 2012 RRS. Orkney Grey
Post #421762 Sun Apr 20 2014 11:18am
