Home > Maintenance & Modifications > lowering a RRS
sammyc1983
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
lowering a RRS
What's the cost of lowering a RRS and is it recommended???
Would love to hear from people that have had it done and what there views are Thumbs Up
Post #420889 Thu Apr 10 2014 5:36pm
MXSRR
England 2007 Range Rover Sport TDV8 HSE Sumatra Black
I think it can be done with the aid of a laptop and the correct software, I'm sure one of the guru's on here will be along to offer some advice Thumbs Up MY2007 RRS TDV8 Black - tinted glass - side steps- stormer grille - 20" diamond cut alloys - alpaca leather - TV/DVD pack - some blingy chrome bits & bob's
Post #420892 Thu Apr 10 2014 5:52pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
Link rods £80 of eBay
Post #420901 Thu Apr 10 2014 7:12pm
PEACHY
Britpart - EAS lowering tool - no mechanics involved Very Happy can be reset in minutes Thumbs Up 16MY Estoril Blue SVR.............
Post #420902 Thu Apr 10 2014 7:14pm
sammyc1983
PEACHY how much would this cost me? also i see from your pictures that you have an autobiography kit fitted where did you get it and have you had any problems or anything..................looks mint bud!!!
Post #420911 Thu Apr 10 2014 9:59pm
blueiceplus
United Kingdom 2008 Range Rover Sport TDV6 SE Cairns Blue
easy Smile done it to mine, no problem got new link rods from ebay £70, and about an hour to fit.
Post #420922 Fri Apr 11 2014 12:08am
PEACHY
Thanks for the comments Thumbs Up
Britpart do a few IID tools - some are more expensive than others & it depends on what your looking to achieve.The EAS only tool is about £180 - £200 & the more specialist tools can be a hundred or so £ more. The reason I used the tool instead of the links is because its plug & play & reversible within minutes.
The AB kit I fitted is Genuine OEM - most of the parts purchased from Duckworth`s - It will be a simple job to do on your Sport - mines a 2005 so a lot more bits was needed. If you have the cash & are not hands on then I would suggest using a company that will do the lot in one hit -purchase the parts - fitting & painting. If not then as TLL suggested you can save money by waiting & sourcing the parts yourself over a period of time.
Whatever you decide good luck. Just shout up if you need any help Thumbs Up 16MY Estoril Blue SVR.............
Post #420933 Fri Apr 11 2014 8:30am
sammyc1983
is the IID tool easy to use myself? yeah i keep hearing about duckworth's just thinking i might be slightly priced out by them at the moment and kinda only wanted to spend 2k-2.5k on body kit........................buying the car has left a huge hole in my pocket Big Cry cheers for all the advise fella!!
Post #420940 Fri Apr 11 2014 11:32am
garrycol
Australia
I just use LLAMs - I can select -20 to +50mm below or above any height selected at the simple selection of a switch.
I normally drive around at 20mm below onroad height with no issues.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #420950 Fri Apr 11 2014 12:22pm
sammyc1983
does the ride feal alot firmer?? was hoping to lower about 40-50mm but don't want a really firm ride
Post #420951 Fri Apr 11 2014 12:26pm
SRE
Spain
Lowered mine circa 25mm, (one inch for old timers) next day put it back to standard, ride does suffer when lowered. Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #420954 Fri Apr 11 2014 12:55pm
I guess, unlike a lot on here, you lowered it not for the looks SRE, but for the ability to get in a little easier at your age Whistle Rolling with laughter ON THE WAY: BMW F21 M140i
Post #420955 Fri Apr 11 2014 1:07pm
PEACHY
Agree with SRE Thumbs Up anything more than 25 affects the ride height on my RRS - it bounces along Rolling with laughter Rolling with laughter 16MY Estoril Blue SVR.............
Post #420956 Fri Apr 11 2014 1:07pm
Disco_Mikey
I dropped an RRS once.
Wanted it as low as possible, regardless of what advice was given about ride quality etc.
Eventually managed to get it to sit just below access height, when the car was in normal mode.
It lasted 45 minutes before he came back Laughing
Post #420959 Fri Apr 11 2014 2:44pm
SRE
Spain
Not allowed to swear on here as the Yorkshire Mods get asrey, Whistle but can I ask BC - were your Mum and Dad Rolling with laughter Rolling with laughter married??? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #420961 Fri Apr 11 2014 4:00pm
