Home > Maintenance & Modifications > aux lamps
Michael calvert
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Nara Bronze
I think so
Drill a 16mm hole and then all you see is the gloss black switch
Press once to turn on so it latches which in turn will illuminate the white led bezel
Push again to turn off turning led light off too
Will need some wires then back from dash to under the hood for the relay unit 2010 RRS HSE 3.0 tdv6 2010MY
2012 Audi a5 2.0 tdi s-line
2005 Discovery 3 tdv6
2009 audi a4 2.0tdi saloon
2007 Audi a3 1.9tdi sportback
2004 Navara Double Cab
1996 Shogun 3.0 v6
1984 Landrover 90 2.5d
Post #420635 Mon Apr 07 2014 10:37pm
Michael calvert
In an old defender my carling switches would be perfect
Can't find a use for them yet unless I throw then on ebay 2010 RRS HSE 3.0 tdv6 2010MY
1996 Shogun 3.0 v6
Post #420636 Mon Apr 07 2014 10:38pm
Marsie
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
think the carling switches may look a bit ott in the sport. You could always fit a raptor dash above the satnav Rolling with laughter Current fleet
2011 Discovery 3.0 sdv6 XS
2008 Range rover sport HST tdv8*gone*
2000 Porsche 911 Carrera 2 convertible
1996 TVR Chimaera*gone*
2004 Vauxhall combo van*dead* Sad
2003 ford ranger double cab
Post #420637 Mon Apr 07 2014 10:46pm
Michael calvert
Ordered the black aluminium latch switch today
Hopefully be here for the weekend so can get them fit
Anyone ever wired up using the full beam as a feed for the relay?
And what about dash removal /replacement is it straight forward once I know how
Done the d3 before today 2010 RRS HSE 3.0 tdv6 2010MY
1996 Shogun 3.0 v6
Post #420704 Tue Apr 08 2014 9:21pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
If they are driving lights then surely you want them to come on and off with your full beam?
Jim
Post #420728 Wed Apr 09 2014 6:59am
Michael calvert
Yeah that's right
So I need to use the full beam wire as a signal for the relay to power the new lights on, with a switch inside that will break the circuit so that the full beam on the car can be used as normal ie without the aux lamps working 2010 RRS HSE 3.0 tdv6 2010MY
1996 Shogun 3.0 v6
Post #420731 Wed Apr 09 2014 7:20am
jim4244
Ahh...all is now clear. I thought that you were going to turn them on and off using just the switch.
Jim
Post #420732 Wed Apr 09 2014 7:52am
