Home > General > Rear Light detterent.
drdelrrs
Since, it seems from the number of posts on here, that rear lights are in danger of becoming a consumable I wonder if we could convince someone (even LR) to make a crescent shaped hard rubber or plastic moulding that fits (screws or glues) to the side of the lamp and closes the gap between the tailgate and the light unit.
Certainly, from the MY10 'Sports' with a one-piece tailgate, there is ample space (hence the ease with which the thieves gain access) between the tailgate and the side of the lamp unit.
Closing this large gap would stop the light being removed rearwards and also prevent access to the light's fixing screws without first removing the moulding which would, of course, require opening the tailgate.
I cant see it being expensive to produce a pair of moulds to enable either a carbon fibre or GRP unit for what would be a simple shape to produce.
Any ideas ?
Post #419870 Mon Mar 31 2014 7:19pm
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
I would back that idea Thumbs Up
Post #419875 Mon Mar 31 2014 8:22pm
muddywheels
Milk Float Man
I had the same idea and been thinking where to get something made Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #419885 Mon Mar 31 2014 10:19pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Whilst I do agree, the rears are easy to make theft more difficult, it's the front which warrants more attention towards a solution.
Post #419899 Tue Apr 01 2014 9:16am
drdelrrs
^^^ To get an idea of the shape I was going to pinch some of my grandson's 'playdoe' and shut the tailgate on it to establish the clearance etc.
Post #419900 Tue Apr 01 2014 9:16am
muddywheels
Milk Float Man
My thoughts were a piece of "L" shaped metal section pre drilled and black powder coated then screwed into side of lights to shield fixing screws. Removal would require boot opening to unscrew Smile
Maybe we could get a Bulk Buy together and ask someone like Ray@RLD to make them Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #419901 Tue Apr 01 2014 9:26am
Paulcp
Had a good look at how the front lights could be better secured this morning & can see a potential solution. Just need to find a suitable bracket at B&Q to modify and will report back.
If my thoughts are correct JLR could mass produce this solution for relatively little outlay.
Still won't prevent them from being stolen but would require bonnet to be open and significantly increase the time required to take them off
Post #420086 Wed Apr 02 2014 12:42pm
Andi
I have security screwed my headlights now along with the grill.
Post #420090 Wed Apr 02 2014 2:37pm
