![]() | Home > General > cost to replace cowl??? |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
Very easy to do. Remove windscreen wiper arms, a couple of nuts. Also remove A pillar covers, a good pull.you may need to replace some clips. The bottom cowl then just pulls off. Install the same way. Otherwise visit your local auto windscreen garage. |
HandsomeWeasel Member Since: 07 Jan 2014 Location: Hertfordshire Posts: 37 ![]() ![]() |
I didn't expect it to be that easy! So im guessing wouldn't be too expensive to get an indy garage to do it then???
From my old memory I think the clips are moulded into the panel itself. Have a look on powerful uk web site or you tube and they show you how to remove different panels. Yes a garage of sort will be able to do this job. 30 minute job. |
