![]() | Home > General > HELP and ADVICE NEEDED |
I get about 450miles from a tank of derv. from a 30 V6 lots of town
Welcome to the forum, there are numerous threads that will answer all your questions if you use the search facility. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
I wouldn't be too concerned about fuel costs. I think my computer says I average 24mpg or so (not sure how accurate that is) but I generally don't consider it thirsty compared to other cars I have had.
simon645 Member Since: 30 Jan 2014 Location: cumbria Posts: 126 ![]() ![]() ![]() |
We got our first 2011RRS HSE three weeks ago, from indy dealer, 12 months warranty 23000miles service history, knew previous owner, |
Loopylou Member Since: 21 Mar 2014 Location: London Posts: 6 ![]() ![]() |
Would you say no different in costs if you are running a BMW or Audi? Sorry to be a pest just want to make sure I'm doing the right thing. Thank you for all your help
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
Haven't had mine long but looks like I'm getting around the 25mpg mark. Tax is £490 and from what I have read the services are not cheap.
I've seen a 59 plate 3l diesel. With a lot of extras in it. It's the facelift model and just over average mileage. I've been checking out some independent dealers this morning and there are a couple on Essex, one further away but a full service and MOT is under £300 and a closer one to just over £400 so that's ok. I suppose I've been lucky and had all my cars serviced from a fantastic mechanic for the last 15 years. I will speak to him and see if he does range rovers he did own a disco so imagine he will which will make it cheaper. I'm planning to keep this car until It dies of old age.
Best of luck Lou. |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
Get a good one and you will not regret it |
Thanks. I was thinking old with low mileage but that doesn't mean it won't come with any problems if not more than newer with just above average! I don't do more than 7 to 8 thousand miles a year. Mainly urban driving. But we do go on road trips so it will be good to be in a car without looking like students with a car packed full just for a weekend away! |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
I'd not use just any mechanic, unless they really know RRS's and have the diagnostic equipment. Here's how I found this out. My mate changed the rear brakes and handbrake pads. No problem, easy and cheap. 30 miles later on motorway the handbrake came on (electronic handbrake). Searched manuals and they said you had to turn some sort of adjuster 3 turns, advice on forums was 10 times ! Mechanic hadn't done either. Problem solved. Until it went into a LR dealer and they said the handbrake pad needs replacing. I said it was done 3 months earlier. They said 'and did you tell the computer on the car that? '. So, apparently, you have to connect a PC to the OBD and inform it that new pads have been fitted so that it can make the electronic adjustments. No problems now for 18 months. Just goes to show that even the simplest of jobs are not that straight forward on modern cars. |
If your annual mileage is that low and comprises mostly urban trips you might reconsider going for a diesel as the facelift cars will all have a DPF; these filters don't much like short trips and can require regeneration and, eventually, replacement.
Thanks B3EEE
rich_z3 Member Since: 16 Feb 2014 Location: Runwell, essex Posts: 68 ![]() ![]() ![]() |
I bought with just above average mileage with full service history , had mine just over a month , done 3500 miles and averaging 27-28 mpg, its a 2.7 tdv6 chipped , |
