Home > Technical > Auto box issue, as if stuck in Sports mode
cubbyno9
Hi all,
I am having issues with my autobox. The car is only changing gear when it is hitting 4500 ish revs, it's as if its stuck in Sports mode. I move it to sports and can change up and down ok. The car then comes up "transmission fault" then HDC fault.
I will be away working for the week and my wife will need to take to garage, could anyone advise me what they think the issue might be, so I have any idea before the garage starts to have a look at it.
Thanks.
Craig 2017 Range Rover Sport HSE
Post #417985 Sun Mar 16 2014 10:01pm
Disco_Mikey
Faulty brake switch or bulbs can cause these issues Thumbs Up
Cheap and easy place to start
Post #418012 Mon Mar 17 2014 7:36am
cubbyno9
Hi Disco_Mikey,
Brilliant just the very thing. I had actually changed the rear passenger brake bulb about an hour before I went for the drive and experienced the issue. I didn't think the bulb would have caused such an issue. My wife changed the bulb over this morning (after guidance over the mobile Laughing ) and the car is driving again without any issue.
Thanks again for your wonderful help, much appreciated.
Post #418053 Mon Mar 17 2014 11:40am
Disco_Mikey
It is so common, it is even listed in the ZF Troubleshooting guide Whistle
I did get your PM, BTW. I am through your way next Wednesday, but you have cured the issue already Thumbs Up
Post #418057 Mon Mar 17 2014 12:10pm
cubbyno9
Hi, I will heading down from Aberdeen on Wednesday so prob will miss you. I have 'Liked' your FB page and saved your mobile number Very Happy
We spoke previously about the ERG valves but I have decided against as the engine is running fine (touch wood) at the moment, getting good consumption but will keep an eye on it.
Thanks again buddy and hopefully speak soon for my service, cheers.
craig 2017 Range Rover Sport HSE
Post #418060 Mon Mar 17 2014 12:30pm
RRS Daz
That little bit of advice has got to have saved you a few quid!
Post #418064 Mon Mar 17 2014 1:29pm
cubbyno9
Hi Daz, absolutely ! this web site is amazing. Bow down 2017 Range Rover Sport HSE
Post #418705 Fri Mar 21 2014 3:47pm
