![]() | Home > Technical > Only one week after MOT! |
Madasmad Member Since: 01 Mar 2013 Location: Crewe Posts: 37 ![]() ![]() |
simon645 Member Since: 30 Jan 2014 Location: cumbria Posts: 126 ![]() ![]() ![]() |
I usually get mine serviced/mot d. including mot in price of service |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
My MOT and service usually coincide too. 2012 SDV6 - it's missing a couple of cylinders
I have it serviced and then I have an oil change in between. My MOT is out of sync and I go elsewhere as my service guy does not do MOT's. The wear light did not come on?? What doesn't kill you only makes you stronger!
Need to having a Word with your service guy I think. |
Presumably only one corner is worn like that? Must be the one without the sensor - which is bloody typical. It suggests a fault somewhere. 2012 SDV6 - it's missing a couple of cylinders
Yes only one corner. |
4 pads per axle 1 sensor, it's only there as a guard.. 2008 G4 RRSport TDV8 current
