![]() | Home > Technical > Video of leak, can you tell where its from? |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 ![]() ![]() ![]() |
Sadly i think ive seen where its coming from, after jacking up the rear, second vid on its way |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9133 ![]() ![]() ![]() |
When mine leaked like that it required a full replacement... |
I think i was kidding myself |
£1,620 OUCH...!!
Sounds about right. It's £800-900 for the anti roll bar and then a lot of labour - it's a body off job I believe. 2012 SDV6 - it's missing a couple of cylinders
There is two systems, early type is £750 ish and the later is £995, gues what one get to have? lol |
mark.b Member Since: 02 Oct 2013 Location: cheltenham Posts: 113 ![]() ![]() |
would it not be covered under a warranty |
Floggitt Member Since: 04 Mar 2014 Location: llandysul Posts: 20 ![]() ![]() ![]() |
Take out a warranty and leave it a couple of weeks then "find" the problem? |
Im far to honest to something like that, im going to get it done by Aylmers, he's rates are not bad. |
The TDV8 has a slightly larger unit than that fitted to other models. That's probably why it's a bit pricier too. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
