Home > Technical > Tdv6 Engine fitted wont start
Page 3 of 4 <1234>
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
oh thanks for that,will check as soon as its stripped ,sounds like a good possibility Bow down silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #416033 Sat Mar 01 2014 12:12pm
gazzc
adigorn wrote:
Did you have gen tool to fit signal ring?
(hope you did mark the camshafts as well )
can you please tell me what you mean by gen tool to fit signal ring,the mechanic helping me said he just knocked it on Question silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #416525 Tue Mar 04 2014 3:45pm
gazzc
getting worse
its getting worse the scanner will not communicate with the engine management now and we have tried 3 different scanners,it will only communicate with body control and we are getting codes b1b02 low frequency coil and b1c57 passive start ignition relay and they will not clear Big Cry silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #416661 Wed Mar 05 2014 11:02am
flack
Check what voltage your getting at each injector just with the ignition on, then let us know, as to me it sounds like you have a main ecu problem, have you checked for water damage at the 3 main sockets and pins..?.
Flack Thumbs Up
Post #416695 Wed Mar 05 2014 3:52pm
gazzc
thanks for reply,i havnt checked ecu sockets,it was running fine before we took the engine out and its been dry stored ever since ,is there anything else that can blow the ecu silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #416725 Wed Mar 05 2014 5:55pm
gazzc
no sign of water ingress at the 3 sockets silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #416810 Thu Mar 06 2014 11:30am
gazzc
Does anyone know. As you have gathered my sport won't start,since refitting repaired engine we have not refitted front end is headlights slam panel bumper suspension etc etc question is could all of this being off cause it not to start : Question silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #417626 Thu Mar 13 2014 8:55pm
Have you disconnected the airbag sensors on the front end ? If so, are they still disconnected ?
Post #417631 Thu Mar 13 2014 9:05pm
gazzc
I'm not sure. Possibly would that prevent it starting silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #417635 Thu Mar 13 2014 9:42pm
Disco_Mikey
No, it will still start with the whole front end stripped.
It will even run with the cambelt cover, and aux belt removed.
Post #417636 Thu Mar 13 2014 9:54pm
gazzc
Ahh OK mike thanks. I got excited then... Big Cry silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #417637 Thu Mar 13 2014 9:58pm
Disco_Mikey
Post a picture of your cam pulleys, as fitted to the engine
Post #417638 Thu Mar 13 2014 9:59pm
gazzc
Will do tommorow thanks for your help Bow down silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #417640 Thu Mar 13 2014 10:05pm
Ah sorry, i was only thinking of possible suggestions as a pal of mine was refitting a front end on his VW Golf and it wouldn't even turn over till all sensors reconnected and radiator refitted etc etc. He had to have all sensors and ecu's reset by the dealer in order to start the car. It had front end damage and airbags had gone off though.
Post #417641 Thu Mar 13 2014 10:07pm
Disco_Mikey
That would be expected, as an accident would throw the car into "crash mode"
With an RRS, all it needs is a cycle of the ignition, and it will start again Thumbs Up
Post #417644 Thu Mar 13 2014 10:13pm
Page 3 of 4 <1234>
