| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Engine warm up and cool down to protect turbo |
| SPX Member Since: 26 Dec 2012 Location: South Yorkshire Posts: 587      | You shouldn't really leave a cold engine idling but there are certain trains of thought that recommend letting your engine/turbo cool down when you've been on a long journey.
|  Wed Feb 26 2014 11:29pm |
| StrangeRover Member Since: 22 Feb 2014 Location: London Posts: 27      | Thanks for quick reply iirc it is due to fuel carbonising or something along those lines .. I think the start up was to gradually warm up the turbo,
|  Wed Feb 26 2014 11:42pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | You want to give the oil system time to get oil to the turbo before you get the turbo hot. Driving the vehicle gently for a few minutes should facilitate this. You also want to allow the turbo to cool a bit and spin down before turning off the oil flow (i.e. the engine) so allowing it to idle for a minute before turning off is a "good thing".
|  Wed Feb 26 2014 11:51pm |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | I have always had mechanical sympathy for all my motors, a gentle warm up off boost, from cold, and always an idle time of 2 minutes after a long journey or after any motorway journeys. Ive never had any turbo problems, but know quite a few that have. | ||
|  Thu Feb 27 2014 9:56am |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961      | I was advised by a LAndrover approved Indie to do exactly that .... give it a short while before hurtling off up the road and before switching off just to allow the turbo's to stay lubricated. 2010 RRS, TDV8
|  Thu Feb 27 2014 10:05am |
| RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797  | I've always done this with anything I've had with a turbo fitte. You can get turbo timer which I used to fit to my jap sport cars. It allowed you to remove the keys from the ignition, lock and alarm the car but leave the engine running for how long you set the timer.
|  Thu Feb 27 2014 10:48am |
| Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158    | I think you should bring your oil up to about 70c before you start giving the beans. I have always warmed the oil on all my cars. Letting the car run for a while depends on whether you have just come from a spirited drive, normally if driven at a lower speed for a while there is no problem in turning it off. Oils, bearings and how the feed pipes work have improved hugely over the years.
|  Thu Feb 27 2014 12:15pm |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163      | Its a good idea, when refuelling mid-trip on a Motorway/Autobahn when temperatures may be high, to allow to engine to tick-over for a few moments before shutting it down.
|  Thu Feb 27 2014 8:37pm |
| MartyRRS Member Since: 04 Dec 2013 Location: Adelaide Hills South Australia Posts: 25      | a long haul truckie gave me this advice - the best way to warm up your engine is to drive it (as opposed to idling). Obviously not to thrash it tho. Re cool down, I have found that EGT's drop dramatically with only a couple of minutes idle before turn off. I dont know about in the UK but down here it is illegal to walk away from a car and leave it running - so even with a turbo timer you should really sit in the car until it turns off..... Regards, Marty
|  Fri Feb 28 2014 6:18am |
| martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324      | I was always told that the oil in a turbo drains off when the engine is off.
|  Fri Feb 28 2014 7:04am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | As above   | ||
|  Fri Feb 28 2014 7:21am |
| Tiny Timmy Member Since: 20 May 2011 Location: Bucks Posts: 233      | Do you have to do this with a supercharger ?............TT | ||
|  Fri Feb 28 2014 8:05am |
| Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 249      | And now they have stop / start on them...   cue all the turbo problems in a couple of years, or less!
|  Fri Feb 28 2014 9:01pm |
| Tiny Timmy Member Since: 20 May 2011 Location: Bucks Posts: 233      | Thats great cheers Andrew, I thought that was the case but i have never seen it written anywhere.....TT | ||
|  Fri Feb 28 2014 9:04pm |
| Posting Rules
