![]() | Home > Maintenance & Modifications > More help needed plz, multiple faults on dash :-( |
| rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879
Was it a genuine bulb they used? Some bulbs even when working cause dash warning lights to come on MY16 AUTOBIOGRAPHY Indus silver with some toys
| TaddyHST Member Since: 04 Jan 2013 Location: Mansfield, notts Posts: 49
Hi mate thanks for the reply, wasn't sure what they used so I've swopped both brake bulbs out for Bosch ones on my way home tonite faults still there but getting the ecu reset tomorrow at garage and diognostics done also so fingers crossed. Simon AKA TADDY
Hey guys I've now swoped the brake switch also and all faults are still there with car still stuck in access height as well even though it drives as normal just really low. Any advice? Plz? Lol Simon AKA TADDY
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
Forgive me if I'm covering old ground - have you tried putting it into extended mode - raise the suspension then lowering - does it work as it should ??? Where is the strange noise coming from - not on the passenger side in front of rear wheel |
No car doesn't raise n lower and the noise seems to come from under the centre of the car Simon AKA TADDY
Is it a vibrating noise ? - does it make the noise without the engine being turned over ? 16MY Estoril Blue SVR.............
| RRSSTEVE Member Since: 17 Jan 2010 Location: POOLE DORSET Posts: 15
SOUNDS TO ME LIKE SOME NUMPTY TECHNICIAN JACKED YOUR CAR UP ON THE SUSPENSION COMPRESSOR BREAKING THE MOUNT AND KILLING THE AIR SUSPENSION PIPES. |
It's more like an electric ticking noise if it wasn't for all the fault lights Ide think compressor but they came up shortly before the car locking in access height |
| martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324
Hi mate, where did you get your car serviced?
Cheers matey I may give them a buz tomorrow. I used Trd performance at hucknal used him for a few years now on previous cars with no bother. I've just took a quick vid of the noise will upload shortly Simon AKA TADDY
You need someone who deals with RRS all the time.
Great stuff cheers mate ile give him a call tomorrow, really appreciate it |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
Loose
Did you speak to Nick? Any joy ?? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
| All times are GMT |
