Home > Technical > Tdv6 Engine fitted wont start
Page 2 of 4 <1234>
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
still cant get it to run ,fires up with a sniff of brake cleaner,its got fuel at the injectors,and cleaned cam sensor,no fault codes...any help would be very much appreciated Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #415456 Tue Feb 25 2014 4:59pm
gazzc
Come on fellas any ideas we are stumped. Oh bought timing tool and its spot on Sad silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #415505 Tue Feb 25 2014 8:39pm
flack
If it starts to fire when you give a squirt of brake cleaner then it must be lack of fuel, have you had the filter off?, does fuel flow from the bleed screw at the top of the engine. Can you here the fuel pump running in the tank. See if you can get a diagnostic kit on it and crank it over to see if the fuel rail pressure is ok..
Flack Thumbs Up
Post #415568 Wed Feb 26 2014 10:44am
gazzc
thanks for reply,yes we have fuel at the injectors,cam sensor is coming up again now,we took it off the other day and cleaned it and the fault code cleared but we ran a scan this morning and its come back so i will order one and try that Confused silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #415580 Wed Feb 26 2014 11:57am
Disco_Mikey
I have never seen a cam sensor fail, in 9 years. The only time I have ever seen a cam sensor fault, is when the timing has been wrong.
It seems very unlikely you would have 2 faulty cam sensors, especially if 1 was OK before the engine was removed
Post #415661 Wed Feb 26 2014 9:56pm
gazzc
yes mike that was my thoughts aswell but im really scratching my head now Confused silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #415720 Thu Feb 27 2014 9:02am
Disco_Mikey
If the fault is still there with 2 different cam sensors, then its likely the cam sensors are OK.
The fault is logged when the ECU doesn't see the cam and crank synchronising (sp?)
So, assuming both sensors are OK, that leaves a wiring issues between the sensor + ECU, a faulty ECU, or timing...
Post #415767 Thu Feb 27 2014 2:27pm
gazzc
Don't you think it could be a fuel problem mike with it firing when I give it a sniff silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #415859 Thu Feb 27 2014 9:05pm
Disco_Mikey
No. Easy start will make any engine run for a few seconds, thats why its called easy start. The fact that it stops running tells you that its either not squirting fuel in, or its squirting at the wrong time. Doesn't mean its a fuelling issue Thumbs Up
Post #415874 Thu Feb 27 2014 10:22pm
adigorn
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
I did a quick read trough your posts
was the engine reconditioned ?
asking cos it is crank/cam synchro issue
You are claiming timing is spot on which really leaves the crank sensor to be at fault
Post #416013 Sat Mar 01 2014 10:21am
Disco_Mikey
Are the cam pulleys on the right sides? They are different Question
Post #416015 Sat Mar 01 2014 10:52am
gazzc
hi yes we fitted a crank/conrod,we have checked timing twice and it seems to be spot on but we are just taking off covers to check again as we cant get to the bottom of it ,thanks Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #416016 Sat Mar 01 2014 10:53am
gazzc
yes mike we marked the pulleys before removing silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #416017 Sat Mar 01 2014 10:54am
adigorn
Did you have gen tool to fit signal ring?
(hope you did mark the camshafts as well )
Post #416019 Sat Mar 01 2014 10:59am
Disco_Mikey
The 2 pulleys are physically different though, and only 1 has the trigger on the back of the sprocket. I meant have the sprockets been fitted to the correct sides?
Post #416026 Sat Mar 01 2014 11:40am
Page 2 of 4 <1234>
