![]() | Home > Technical > hdc problem |
| Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522
Not sure about the wheel but the HDC and special programmes sounds like your batteries gone |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9154
Check your brake lights - a blown bulb can cause HDC errors.
| blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66
checked all these today, battery & charging been tested, bulbs, all good, front pads, and wear sensors abs sensors, brake warning light comes on first, n/s front wheel still locking on and off, caliper all ok and free,
Have you tried driving with the DSC turned off? If so, does it still produce the symptoms? Could be a faulty yaw sensor or steering wheel angle sensor causing the DSC to think you're sliding and so using the brakes to try to keep you on the correct course. 2012 SDV6 - it's missing a couple of cylinders
a yaw sensor, |
The yaw sensor sits on the floor under the centre console and is used by the DSC to determine yaw rate (unsurprisingly).
well that's what i thought it would measure, but still none the wiser to what the yew is to be measured ?
As the vehicle turns a corner, it experiences yaw - that is a rotational moment about the centre of its wheelbase. There is a maximum amount of yaw that can be attained whilst all four tyres are gripping. If the yaw exceeds that figure then the rear tyres have lost grip and a spin is about to occur. By comparing the yaw and the steering angle it's possible for the DSC system to determine whether the front or rear has lost grip (for example, reducing yaw with no reduction in steering angle would indicate the front tyres have lost grip and understeer is occurring).
Could be as simple as the steering angle sensor needing calibrated, but needs plugged in to check the live data |
collected rrs today |
another new battery today 900 amps, steering angle recalibrated, codes cleared again, test drive and the dash lights back on, this time code comes up for turbos, garage checking for split turbo pipes, |
| jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
Well, the other day I found out that HDC is only working when you drive forward.
HDC does work in reverse. HDC is overridden by the brake pedal - if you touch the brakes then the system puts you back in control. 2012 SDV6 - it's missing a couple of cylinders
HDC does indeed work on reverse.
