Home > Technical > Limp Mode
PaulHH
Scotland 2006 Range Rover Sport Supercharged Stornoway Grey
Limp Mode
I have the following issue. On the same hill around 20 miles from me and only going the one way I get a error message "System Fault Message" and the car goes into limp mode. Usually I can stop, turn off for 30 secs, restart and all is good although the error message takes about 5 mins to disappear.
So far I have replaced the Brake Light switch, reasonable argument for this. I have replaced the Coolant Temp Sensor as Peachy has had a similar experience but neither has fixed the problem.
I haven't had the codes read as the nearest dealer is 30 miles away but maybe my next stop.
Has anyone any further ideas what might be causing this? its a very strange fault as it doesn't appear on any other roads except the one road, it is a pretty steep hill coming south out of Inverness. 2006 Supercharged
Post #414822 Thu Feb 20 2014 6:25pm
Silly question - have you checked the oil level? Just wondering if the steepness of the hill (and it only occurring going one way on the hill) indicates a sensor registering a dangerously low oil level. No idea if this a possible cause but it's an easy check. 2012 SDV6 - it's missing a couple of cylinders
Post #414835 Thu Feb 20 2014 7:07pm
PaulHH
Cheers for that but yep, oil level is good. 2006 Supercharged
Post #414836 Thu Feb 20 2014 7:10pm
flack
Sounds to me like a fueling issue.. You need to get the codes read as a starting point.
Flack Thumbs Up
Post #414856 Thu Feb 20 2014 8:24pm
Disco_Mikey
Where in the country are you? I may be up in Inverness in the coming week Thumbs Up
Post #414859 Thu Feb 20 2014 8:54pm
PaulHH
Mikey, i'm in Carrbridge, just North of Aviemore. If you're going to be up here that would be great. 2006 Supercharged
Post #414861 Thu Feb 20 2014 9:00pm
PaulHH
Mikey, are you going to manage to be up my way this week? 2006 Supercharged
Post #415359 Mon Feb 24 2014 10:10pm
