![]() | Home > Technical > Coolant Temp Sensor |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Pm sent |
Paul - another pm sent |
PaulHH Member Since: 24 May 2013 Location: Highlands Posts: 98 ![]() ![]() ![]() |
Hi Peachy, didn't get the job done today, did find the sensor, it's hidden under the air intake so I'll get it changed out hopefully over the next couple of days. It was freezing up here today, tooo cold. 2006 Supercharged |
Eventually got round to fitting the sensor. Went out to test it and see whether I could reproduce the fault and yes, car still goes into Limp mode on the same hill with the "System Fault Message"only this time the fault message won't go off. The car is running fine but the error is continually showing. |
It took me long enough.... forgot there would be a little pressure in the coolant system too....lol 2006 Supercharged |
