![]() | Home > General > Side Steps/Premium leather |
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 ![]() ![]() ![]() |
I dont think side steps will make much difference....Using access height when getting in and out will do the same job. As for the creases, I'm not sure you can get them out.....They seem to appear through time on every RRS, you can disguise them a little through different products but I doubt you can remove them completely...It is leather after all and leather will crease through wear. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9090 ![]() ![]() ![]() |
The sidesteps can help prevent side creases so long as everyone uses them. My good lady insists on sliding off the side of the seat - which causes the creasing. I hav mentioned this to her on a number of occasions. This also causes creases as she frowns at me... |
Nav01 Member Since: 18 Jan 2013 Location: North London Posts: 99 ![]() ![]() |
lol I do use the comfort access but God man made 5ft.10in age has man made 5ft.9in. Yes i educating my lady how to handle her derriere when ejecting herself from the cabin as no crease's on the passenger side for the time being.
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 ![]() ![]() |
Leather is a skin and skin creases with age you can help by cleaning and moisturising as you would your own skin it helps.
"short of leg" myself mate at 5'7 and without access height enabled I find getting in the car awkward, I have sidesteps fitted but like your mrs still slide off the seat getting out ![]() ![]() ![]() 2006 RRS TDV6 2.7 HSE -Java Black 2008 BMW 3 Series 2.l 2006 BMW 5 series 2.l |
Hi all ordered the AB front and rear bumpers from Dan at Duckworths. Just need to sort out a set of sides steps need your valued opinons thought I would go with non oem side steps from what I have read on this site, had a look around on ebay they go from £140 upwards, sites like powerfuluk sell at £220. On ebay some have base made out rubber ie the (Black grip part) for non slip most others are plastic so are powerfuluk . What are the OEM? is it better to go with rubber matting base or just plastic base?
