![]() | Home > General > suspension red light then... |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Could be the Air Suspension Compressor - did you have any previous warning lights appear - these would be yellow advising ride height only & showing a symbol of the car with arrows above it.Was the compressor noisy - it lives in front of the passenger rear wheel.If it is the compressor I've never known the failure to cause punctures or total failure without warning. |
onethumb Member Since: 09 Apr 2013 Location: wolves Posts: 30 ![]() ![]() ![]() |
Hi PEACHY, no warning lights before, no extra noise, yes two front wheels are normal height, just started it up and there was no message the dial was saying it was at max ride height so turned the dial and pump started now its back to normal. This is more worrying. more help I think. RRS 2006 supercharged
Could it have been the puncture FIRST not the EAS failure ? |
Hi PEACHY, thanks for your reply, Would that cause the both sides to drop all that way down?
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
it would if debris or something has punctured/snapped the suspension pipe work as both sides are linked together on the rear, when i had a leak both sides dropped, but the leak was on nsr |
update:
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
I dont want to swap wheels but i am really pleased you got it sorted mate |
These must be local to you http://www.equicar.co.uk/breakers/breaking...2=Go+-+%3E no harm trying |
thanks PEACHY, will call them in the week, I've used them before, they are not cheap but they do have good stock |
Update, today got two new tyres fitted as didn't know if the other rear had been run flat either so to get rid of any doubts and due to comments about same tyres on axels, thought better safe and have less money |
By the way the other tyre was fine so didn't need to replace |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
our sc cars come with the black 19 as a standard spare wheel. Hope you get ot sorted. Keep us posted. |
