![]() | Home > Maintenance & Modifications > 3.0 tdv6 engine conversion from a 2.7 tdv6 CAN IT BE DONE? |
Nothing is impossible if your pockets are deep enough, but it would be a major job as the wiring loom is completely different, the main ecu is different, the turbo's are different I would think unless you have access to some top end diagnostic to change it all then I don't think it would be worth the effort..
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Mr Flack. Do you know if the ancillaries from the 2.7, will physically bolt onto the 3.0 block? |
Not sure Mickey but I would think there would be differences, as you know some parts are quite a different shape on each model..Most of the coolant pipes are different and I think the egr valves are also not the same.
