![]() | Home > Wheels & Tyres > Help!!! 20" that don't fit over brembos... |
bl74beano Member Since: 08 Sep 2013 Location: Perth Posts: 74 ![]() ![]() ![]() |
Hi All,
All 53mm offset...
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4506 ![]() ![]() ![]() |
Are you sure they are genuine, and not replicas? Sounds like they are for an 02-05 FFRR. I had the same issue with mine, and had to sell them on again, and buy another set. Mine were replicas BTW |
Real for sure they were still in the boxes, everything tickity Boo, but they were 58mm offset (there are 2 variants of this style it would appear) and I was told the 53mm was the one I needed. They are actually FFRR Vogue wheels. Apparently even if they have the same brembos the offset is different (the brembos are also different post 2010, which may be the issue here...) |
Cheers Fkarim... these are the ones I'm least keen on but may end up going with them just to be safe ... good to have at least one confirmed as good (these are actually a RRS wheel so I was fairly sure they'd be good).. |
