| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > parking sensors fault |
| JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186      | Have you checked the front ones? 2014 L405 SDV8 RR Autobiography  | ||
|  Tue Feb 04 2014 9:46pm |
| medders Member Since: 03 Feb 2014 Location: portsmouth Posts: 148      | Yes and got nothing :-/ | ||
|  Tue Feb 04 2014 9:47pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | Any error messages   | ||
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494    | With car running and park brake on select a gear preferably with some one sitting in with foot on brake put your ear on each sensor and listen for a clicking noise the one that doesn't click is faulty and will throw all of them off. But first check the wires going to them as they break/split  | ||
|  Tue Feb 04 2014 10:01pm |
| medders Member Since: 03 Feb 2014 Location: portsmouth Posts: 148      | Thanks will try that next, only tried it with the engine off  | ||
|  Tue Feb 04 2014 10:26pm |
| medders Member Since: 03 Feb 2014 Location: portsmouth Posts: 148      | . No error messages   | ||
| medders Member Since: 03 Feb 2014 Location: portsmouth Posts: 148      | no noise from the PDC :-/ DONT NO WHAT IT CAN BE | ||
|  Tue Feb 18 2014 10:50am |
| Gary7734 Member Since: 22 Nov 2013 Location: Banbury Posts: 19      | Have had similar problems myself and garage eventually found one of the sensors had leaked water in, thankfully under warranty as each sensor had to be disconnected and then the system tested until they found the faulty one. | ||
|  Tue Feb 18 2014 12:26pm |
| medders Member Since: 03 Feb 2014 Location: portsmouth Posts: 148      | Think I'm going to take it to a 4x4 specialist to get this sorted once and for all | ||
|  Tue Feb 18 2014 12:40pm |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163      | Medders - I think since you've just had the cam-belt and other things done it might be worth checking the under-bonnet connections and fuses. | ||
|  Tue Feb 18 2014 12:50pm |
| medders Member Since: 03 Feb 2014 Location: portsmouth Posts: 148      | I spoke to the 4x4 guy and he said if there nothing on the dash then could be a fuse ..... Anyone no what number fuse and where as again I'm new to the range rover  | ||
|  Tue Feb 18 2014 1:00pm |
| Posting Rules
