![]() | Home > Maintenance & Modifications > Tdv6 remap with blanked egr |
Your ESF warning will be due to a seized actuator rod. Fairly common issue, and can be lubricated, and freed off in place |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
I think that what you think is turbo lag is not - it is the gearbox trying to work out what it wants to do. As an experiment try driving in Command Shift and changing down and up manually - I think you will find that the "turbo" lag is gone - if it is there it will show up in a drag off the line.
| Fireblade170 Member Since: 31 Jan 2014 Location: Ss178hn Posts: 3
Hi disco Mikey, thanks - this is what I assumed from the fault, is the clean a simple spray with wd40 and push the rod by hand or would running TSO clean it?
Yep spot on - I have found the gearbox only changes down to 3rd or 2nd while you are still moving and when you floor it the gearbox doesn't know what to do for a moment (this feels like turbo lag) then it decides that you want go and changes down and takes off like a scolded cat.
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Re the "lag" issue, have you tried cleaning the MAP sensor? A 5 minute job and many find it seems to improve the responsiveness.
Yes forgot about that - I cleaned mine when I blanked it and didn't make any difference but others have found it useful.
Cheers guys, I will certainly try the MAP sensor ( as soon as I find out where it is). Do you recommend taking out the butterfly valve in the intake body as I've blanked the ergs? |
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494
be carefull when cleaning map sensor,i cleaned mine the other week with a bit of brake cleaner and a fine cotton bud and it knackered it |
| All times are GMT |
