Home > Technical > alarm and central locking query
jon2014
Hi, I have a query re alarm and locking
ive noticed that when I lock the car (2010rrs) with the key fob the alarm sets and all appears normal. However the doors dont lock properly. If I pull the door handle, it opens and the alarm goes off.
It only recently started this. Is there an easy fix?
Thanks
Post #411281 Mon Jan 27 2014 11:14am
Is your model a keyless ignition?
Post #411283 Mon Jan 27 2014 11:29am
Paddi
Yes. It is usually a faulty door latch. The electric motors driving the lock/unlock become weak and don't complete the locking action.
Remedy is to change the latch which is a complete module costing about £80 and an hour to fit. Quite easy DIY and if you search this site and the Disco3 site you'll find detailed instructions with pictures. 2008 MY Java Black TDV8 HSE
Post #411285 Mon Jan 27 2014 11:32am
jon2014
Yes ady is keyless ignition
Post #411287 Mon Jan 27 2014 11:50am
jon2014
Tks paddi. If this is the case wd it be xovered under warranty?
Post #411288 Mon Jan 27 2014 11:52am
Once you have locked your door, take the key fob out of range approx 1m +. Leave the key fob out of range and then try the door again. I suspect the door is opening because the fob is still in range. Which it is designed to do. Wink
Post #411289 Mon Jan 27 2014 11:55am
jon2014
Ha ady. I left it 20m away and tried the door . It still opened.
Not everytime tho
Post #411296 Mon Jan 27 2014 12:28pm
As Paddi surgests then, faulty door latch. Whistle Should be covered under warranty, mine was. Thumbs Up
Post #411312 Mon Jan 27 2014 1:33pm
martyn05
Had my drivers door latch changed today.
I would lock the car using the remote, pull the drivers door handle and the door would open, sounding the alarm.
The small black tab under the door opening lever was sticking out proud a bit when all the others were flush to the door.
If I pushed it in when I got out of the car, it would lock fine but I just got it changed. £80 for the part + 1 hour labour and vat to sort it out.
Hopefully all sorted now. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #429176 Wed Jul 02 2014 9:18pm
Michael calvert
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Nara Bronze
How do you know which lock has failed? ? 2010 RRS HSE 3.0 tdv6 2010MY
2012 Audi a5 2.0 tdi s-line
2005 Discovery 3 tdv6
2009 audi a4 2.0tdi saloon
2007 Audi a3 1.9tdi sportback
2004 Navara Double Cab
1996 Shogun 3.0 v6
1984 Landrover 90 2.5d
Post #430301 Sun Jul 13 2014 9:48am
martyn05
Like I said in the post, the small black tab under the lever was sticking out a bit on the drivers door. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #430315 Sun Jul 13 2014 12:57pm
Paddi
The lock that has failed will be on the door that you can still open by pulling the external handle after the central locking activated and alarm set. 2008 MY Java Black TDV8 HSE
Post #430317 Sun Jul 13 2014 1:38pm
Michael calvert
Found it. The front passenger wasn't locking sprayed some wd40 in it and seemed to work....that was in the drive anyway went out today, parked up and yeah...It wouldn't lock
After a minute or two of trying though managed to work out a temp fix....here's what I did
Before switching off lower window on offending door
Manually lock offending door by leaning through and flicking the switch
Using remote press once to lock remaining doors and boot
Then press again holding button to shut said window
Worked for me 2010 RRS HSE 3.0 tdv6 2010MY
1996 Shogun 3.0 v6
Post #430395 Mon Jul 14 2014 12:11am
ilard
TOP TIP: avoid the inconvenience of door latch repairs by exiting your RRS through open windows thus reducing wear on the mechanisms. I never saw the Duke brothers having to fix theirs, so it's tried and tested. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #430877 Fri Jul 18 2014 7:04am
johnb8538
Worked for me
After spending a few nights wondering how to resolve this I tried your guidance and it worked great. A temporary fix of course as the actuator has clearly failed but at least I can go to sleep at night now. Many thanks.
Post #469477 Tue Aug 04 2015 9:22pm
