![]() | Home > Maintenance & Modifications > Parking sensors |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942 ![]() ![]() ![]() |
Sounds like one is faulty somewhere. Have you got them very wet recently? A wet sensor will give what you describe. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
Yeah don't go near them with the jet wash sent mine crazy fo ages... |
K80tcg Member Since: 29 Mar 2013 Location: Verwood Posts: 25 ![]() ![]() ![]() |
The car been sat in the sun today and long beep has stop to little ones which then stops, they started working, but the tone cuts in and out.
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Had exactly the same problem - during dry periods - not a problem as soon as it rained - intermittent fault. Eventually they will give up |
Where the best place to get a code reader from. Does it tell you which one of the eight has gone ? Tdv8 range rover sport
Silly questions, if the sounder at the back is holding the long tone does that mean the rear sensors is at fault? Tdv8 range rover sport
