![]() | Home > Maintenance & Modifications > Service Reset |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
You can reset them without any equipment!!! 2x TDV6. SE and HSE. Both returned to sender with issues👀
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9155
The thought I had was "how can they check and clear faults if they can't even reset the service indicator?" 2012 SDV6 - it's missing a couple of cylinders
Have to confess, the thought I had was not much of a specialist if they don't have basic service and diagnostics. |
Not on an 05MY you can't Can only do it through the dash on 08>on MY's
Would be more worried about this though. Even an entry level Snap-On computer can clear service lights... |
Mmm. I tried doing an 05 disco and ended up doing it with Verus but my 07 could be done with dash button. 2x TDV6. SE and HSE. Both returned to sender with issues👀
The exception is the cars that have had the IPC updated to 08MY spec |
""I see" said the blind man..... Makes a bit more sense then. |
| chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219
lo all,
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
If he has the diagnostic tools for your car there should be no reason to travel to a dealer...even the most basic tool does it. Mike
Any local car garage that uses snap on can do it. Sonus or Verus does reset it as does autodata. Bit far from me to offer my help |
I'm in Leicester during the week if you wanted it done and/or some software updates.
Ian, only tried it on one car, but yes, it worked with the 08MY IPC software |
I'll have to ask some of my customers to give it a go! |
Tried it yesterday on another car I had done, and wouldn't work. Must depend on which other software has been upgraded |
| All times are GMT |
