![]() | Home > Maintenance & Modifications > How to fit a new instrument dial cluster set RRS 2005-2009 |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 702 ![]() ![]() ![]() |
Grimps did u get any joy with info doing this job?im lukin at doing mine aswel soon I've already got the clocks Java black 2006 |
Grimps42 Member Since: 28 Oct 2013 Location: Norfolk Posts: 23 ![]() ![]() ![]() |
No replies as yet but will let u know if someone responds |
Where is the after market one.. Also the Ipack contains the CCF file which tells the car what configuration's it set to, You might also have problems with mileage settings. All your ECU's are sync to the Ipack so it knows what connected in the car.
Sorry Flack all I am after is changing the dial set to an after market type maybe a plasma illuminated one, rather than the OEM one on the car. |
Same here, I have the overfinch replacement white dials Java black 2006 |
